computer interface
Discussion in 'The Projects Forum' started by raks_universe, Feb 23, 2010.
  1. raks_universe
    Thread Starter Active Member
    Mar 15, 2009
    67
    Hi ...
    I have to do a mini project of controlling a fan and a light using computer.....
    Pls help me in doing this project...
    I dont have basic knowledge about interfacing......
    Pls help me..
  2. t06afre
    May 11, 2009
    5,939
    1,222
    Your teacher must have given you some guidelines like which interface you should use. We can not help you if you hold back any important details
  3. raks_universe
    Mar 15, 2009
    67
    sir..
    Computer interfacing is not in my lessons ,but im very interested in this....
    Pls help me in learning computer interfacing,,,,
    Where can i find tutorials for beginners (starting frm "what is computer interfacing"),,...
    I searched more but i cant find detailed lessons for beginners ....
    Pls help me,,,,,,
  4. t06afre
    May 11, 2009
    5,939
    1,222
    Many beginner projects use RS232 communication. If you have accsess to a RS232 port on your computer, so start with this interface. Will you have a microcontroller in your project?
  5. John P
    Oct 14, 2008
    1,638
    225
    Nowadays it pretty much has to be USB. Serial and parallel ports are just not around much any more.
  6. Wendy
    Mar 24, 2008
    20,772
    2,540
    On newer machines, the older machines they are still standard. However, I understand that XP has a problem interfacing these ports directly, so it is a double whammy, Win98SE and an old computer. The good news is that will set you back around $25.
  7. raks_universe
    Mar 15, 2009
    67
    No sir...My project does not include microcontrollers....
    Im only in beginning level(yet to study).....
    If it is necessary to use microcontroller for this project, (no problem) i ll manage it by doing xtra homeworks ....
    Pls guide this project with and without microcontrollers...which will help me to understand microcontrollers too.......
    Thank u;).....
  8. cezar
    Feb 28, 2010
    I am new and a beginner about computer interfacing.
    hope to learn from all of you.
    i have currently downloaded Visual basic 2008.
    i searched in youtube that some people are able to interface it with their appliances.
    what would be my next step?
    what is a simple interface using?? parallel , serial or USB?
    hope you guide me in my quest for knowldge
    forever grateful to you all;
    -cezar
  9. cezar
    Feb 28, 2010
    also sir i can help you with microcontrollers am a little knowledgeable about it.
    i used to program it in C language.
  10. MarkTBSc
    Feb 27, 2010
    6
    The absolutely simplest way to do this is with the parallel port if you have one available. You can use Visual Basic to control the Data bus which gives you eight lines that can be used as outputs or inputs. You can also use the Status and Control buses but then you have to makes sure the pins aren't input only or inverted.
    You can just run an LED off of the parallel port with no modifications but you may need to switch a higher current supply to run your fan.
  11. raks_universe
    Mar 15, 2009
    67
    Sir,
    Im very beginner .....
    I think ur suggestion is next to my level....
    For interfacing concept ,what is the knowledge requirements....???
