Computer connected to motor
Discussion in 'The Projects Forum' started by fireintheit, Oct 4, 2014.
  1. fireintheit
    Jun 14, 2014
    16
    I was wondering if any one new any good ways to connect a computer to a motor. I need to be able to send signals to the motor from a computer.
  2. shteii01
    Feb 19, 2010
    3,504
    512
  3. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,522
    Gecko's or Larkin Viper.
    Max.
  4. Sensacell
    Jun 19, 2012
    1,183
    276
    It really depends on what type of motor, and how much control you need over it.
    It could be done with a single $0.50 MOSFET- to turn a small DC motor on and off, or you could use a complete motion control unit costing thousands. Define the the task.
  5. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,522
    A single stepper motor and a step/dir drive + P.Supply running Mach3 through the P.P. would cost around $300.00 - $500.00, any other mechanics of course is over and above this.
    A servo motor with encoder would be up to around half again.
    This is if you want to control speed, accel/decel and position.
    Deals can be found on ebay, but generally you get what you pay for.
    Max.
  6. ramancini8
    Member
    Jul 18, 2012
    447
    119
    Using black duct tape, tape the computer to the motor. Although this answer is flippant, it answers the question asked, so maybe you need to be ore descriptive in your question.
    sirch2 likes this.
  7. fireintheit
    Jun 14, 2014
    16
    I was looking to drive a stepper motor with a computer. I was hoping to use a computer to send an electrical signal (I could amplify signal) to the motor. I would probably use a stepper motor for this project.
  8. ISB123
    May 21, 2014
    1,240
    531
    Get a 9$ arduino clone from ebay and L293 motor driver.That will enable you to control the motor via PC/arduino.
  9. shteii01
    Feb 19, 2010
    3,504
    512
