1. fireintheit
    Jun 14, 2014
    16
    I know that the cpu interacts with i/o devices through a bus. I was wondering what is physical hardware used to make the bus?
  2. shteii01
    Feb 19, 2010
    3,521
    515
    Resistors, transistors, maybe some diodes, copper wire.
  3. MaxHeadRoom
    Jul 18, 2013
    10,873
    2,530
    Slots and edge connectors for various expansion card standards e.g. PCI etc.
    Max..
  4. bertus
    Administrator
    Apr 5, 2008
    15,809
    2,390
  5. MrChips
    Oct 2, 2009
    12,658
    3,461
    bus is simply a word used to label a concept that is somewhat imaginary.
    The real bus is simply a wire, junction or node in the circuit. It is implemented with conducting wire, usually made of copper.
    ErnieM likes this.
  6. Fibonacci
    May 23, 2014
    25
    5
    In the development of microcontrollers, from the beginning of the 70s, the bus has been reference to denote the capacity in management of data and memory addressability. They usually have three types: data bus, address bus and control bus, which, as already stated, are physical connections of copper cables.
