Computer Architecture Help
Discussion in 'Homework Help' started by puza18, Feb 4, 2014.
  1. puza18
    Feb 4, 2014
    Show 3 computers, using diagram with different number of data channels, address channels and bit allocation to op-code field and contrast the followings:
    -number of different commands that different computer could issue
    -number of different addressable locations that computer could access
    -data transfer rate per fetch for the different computers
    -length of the instruction register of the different computers
  2. crutschow
    Mar 14, 2008
    13,521
    3,390
    Sounds like an interesting problem. Good luck with your research into that. Or do you just want us to do the work for you? :rolleyes:
  3. puza18
    Feb 4, 2014
    Need a help with the question I have encountered. If you know the answer, please share your answer.
  4. crutschow
    Mar 14, 2008
    13,521
    3,390
    Your first post is not a question (note there are no question marks). It asks to do 3 different design approaches for a computer architecture and compare them. If you have specific questions about how to do that, then post them, but don't expect us to do the designs.
  5. WBahn
    Mar 31, 2012
    18,093
    4,920
    What question have you encountered?
    My crystal ball is in the shop.
