Hello to all and thank you in advance for any insight you can give me. I installed an outlet plug for my three wire 240v 30 amp air compressor today and when it turned on, I shut off the breaker to make sure I had the right circuit. I made the change, tried it and it was working fine. I did the same thing again, when it was running I tripped the breaker to reroute a wire. Now it will not work, nothing at all, not a sound. I have never used the breaker before to turn it off and am afraid I messed something up. It has power into the motor on the two hots according to my meter, pressure switch is fine. I tried the red reset button, spinning it by hand, and letting all air out. Please help.
