Compression/Tension force sensor
Discussion in 'General Electronics Chat' started by bug13, Jan 15, 2014.
  1. bug13
    Feb 13, 2012
    1,210
    38
    Hi guys
    I am looking for a compression/tension force sensor, it needs to be able to handle +/-500N, where can I find one??
    Thanks a lot!!
  2. elec_mech
    Nov 12, 2008
    1,513
    193
    It's been awhile since I've used these, but if memory serves, S-Beam load cells can do both compression and tension. 500N works out to ~112 lbf, so a 200 lbf sensor here might work. You'll need something to read the sensor.
    More sensors from the same company here.
    You can Google load sensor and s-beam sensor to find more suppliers, perhaps one closer to you.
    bug13 likes this.
