Component to VGA - Breadboard?
Discussion in 'The Projects Forum' started by Dalaran, Sep 23, 2011.
  1. Dalaran
    Thread Starter Active Member
    Dec 3, 2009
    168
    I am planning to build a component to VGA converter following the LMH1251 evaluation board: http://www.national.com/an/AN/AN-1836.pdf
    I have just received the National ICs and soldered them to the TSSOP/SSOP to DIP boards. I was planning to test this out on a breadboard as I always do, but am now thinking it might not work with such high frequencies as in component and VGA signals. Do you think I will be wasting my time? Are the 0.64mm square pins that come with it going to be alright? Maybe I am just better off to start with a protoboard... will that even work?
  2. Dalaran
    Dec 3, 2009
    168
    Or should I go straight to attempting my first PCB layout?
  3. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
  4. Dalaran
    Dec 3, 2009
    168
    Do you think this could be done by soldering to a proto board? I'd like to have some confidence in getting this going before trying to do the PCB layout and manufacturing of it.
  5. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
