Component suggestion
Discussion in 'General Electronics Chat' started by Tobias, Jan 31, 2010.
  1. Tobias
    Thread Starter Active Member
    May 19, 2008
    158
    I want to make a 'kill box' for a motorcycle. In essence ground out the coils. I will control the amount of time with a PIC chip. I am not sure on the component to ground out the coils. Any suggestions? I don't know specifics for voltage etc on the coils but its a motorcycle application.
  2. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,390
    What is the purpose of a "kill box"?
    Is it an anti theft device?
    Bertus
  3. Tobias
    May 19, 2008
    158
    Interrupt the ignition to shift.
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,729
    Is the bike fuel injected? If so, you would be better off killing the injectors. Otherwise, you'll fill the exhaust system with fuel/air mixture, and when the ignition comes back on you'll get a very loud bang as it lights off.
    If you ground the coil(s), you'll cause them to saturate and rapidly overheat them. Expect a short life span.
  5. Tobias
    May 19, 2008
    158
    The bikes are carbureted. What component would you suggest to ground the coil? The event is only going to be for 0.08 sec.
