Component name
Discussion in 'General Electronics Chat' started by bwaley, Jun 30, 2009.
  1. bwaley
    Jun 1, 2008
    27
    What component is represented by FB--(i.e FB9001) in a circuit boardof a monitor?
  2. Lanz
    Oct 30, 2008
    153
    Perhaps you could give a detailed or more info on that component for us to identify it.
    A picture or some other clue?
  3. bwaley
    Jun 1, 2008
    27
    it resembles a diodie but with no mark, i thought FB represent a component one could easily tell because in the same CB a component c6005 is a capacitor whilest R 4006 is e resitstor. help
  4. R!f@@
    Apr 2, 2009
    8,785
    771
    it is a fuse or a link. nothing more. It should show a short circuit.
    Rifaa
  5. KL7AJ
    Nov 4, 2008
    2,043
    292
    Without further elaboration, I would take that to mean ferrite bead.
  6. R!f@@
    Apr 2, 2009
    8,785
    771
    Nope dude. ferrite beads are bit loose and has through wires. :p
    Just links or Fuse, I am sure of it.
    Rifaa
  7. ELECTRONERD
    May 26, 2009
    1,146
    16
    A ferrite bead sounds right to me.
  8. Papabravo
    Feb 24, 2006
    10,338
    1,850
    I vote for ferrite bead, not withstanding the vehement response to the contrary. Maybe you could post a picture.
  9. hgmjr
    Jan 28, 2005
    9,030
    214
    Here is a excerpt from a data sheet that would appear to support the ferrite bead proponents.
    hgmjr
  10. bwaley
    Jun 1, 2008
    27
    thanks solved my puzzle
