Component Identification.
Discussion in 'General Electronics Chat' started by R!f@@, May 20, 2016.
  1. R!f@@
    Thread Starter AAC Fanatic!
    Apr 2, 2009
    8,789
    771
    I attached a picture of a component that I never came across before.
  2. MrChips
    Oct 2, 2009
    12,633
    3,453
    100ns delay line?
    Dr.killjoy likes this.
  3. R!f@@
    Apr 2, 2009
    8,789
    771
    Really ?
  4. GopherT
    Nov 23, 2012
    6,309
    4,029
    I would guess it is a 100nF cap with an "S" tolerance factor (+/-22%), just a guess. What does your capacitance meter say?
  5. Kermit2
    Feb 5, 2010
    3,849
    965
    I add my vote for a delay line.
    Does it ohm out steady, or rising like a cap?
  6. dl324
    Distinguished Member
    Mar 30, 2015
    3,377
    651
    +1 for capacitor.
    I have a box of these 2.2nF 1KV caps:
    GopherT likes this.
  7. R!f@@
    Apr 2, 2009
    8,789
    771
    I did not check with DMM.
    Will do tomorrow and post back
    PS. Will you believe if I say that I have been using this component for like 20 years. o_O
    Unknown to me that it is there doing what it does in my PSU :p
  8. benta
    Member
    Dec 7, 2015
    101
    24
    It's a 100 nF ceramic multilayer decoupling cap.
    I remember these from the 80/90's, manufacturer was Siemens in those days (I think).
    The S is the voltage, in this case probably 50 V.
    Benta.
  9. panic mode
    Oct 10, 2011
    1,328
    305
    +1 for cap... i must have tons of them from the old days...
  10. benta
    Member
    Dec 7, 2015
    101
    24
  11. ericgd
    May 20, 2016
    This is a conductor (or resistor). "S" stands for "Siemens."
  12. R!f@@
    Apr 2, 2009
    8,789
    771
    A conductor ???? o_O
    100 nano Siemens ???
    I need to go back to Engineering School.:eek:
  13. ericgd
    May 20, 2016
    for conducting heat.
  14. R!f@@
    Apr 2, 2009
    8,789
    771
    Come again !
    What heat ? And where ?
  15. grahamed
    Member
    Jul 23, 2012
    99
    11
    LOL. 100 nano Siemens would be 10Mohm I think, which would be easy to check, unless it is a leaky 100nF cap.....I am voting for cap - leaky or not.
  16. ian field
    Oct 27, 2012
    4,447
    791
    The ones of those I've seen plenty of were all capacitors.
    100n is sufficient to give a kick on high Ohms range on an analogue meter.
    Some types of continuity testers with LED indicator will blink if you test a cap with them.
  17. GopherT
    Nov 23, 2012
    6,309
    4,029
    At 10M Ohms, more like resisting the conduction of heat. Good electrical conductor = good heat conductor. There are a few exceptions but it is a good general rule. BN, diamond, SiC are notable exceptions.
  18. Lestraveled
    May 19, 2014
    1,957
    1,218
    +1 for a capacitor.
    A delay line would require a third terminal (ground).
    S is the tolerance
  19. benta
    Member
    Dec 7, 2015
    101
    24
    I give up.
    Once again: it's a Siemens Sibatit 100 nF multilayer ceramic cap.
    Period.
    bwilliams60 and GopherT like this.
  20. R!f@@
    Apr 2, 2009
    8,789
    771
    Yaaaay!
    It's a cap.
    Meter shows 97.5nF.
    Continuity shows nothing.
    Can I replace it with a monolithic ceramic ?
    I'm going to remake the old PSU. It's like more than 20 years. But a very reliable one.
