Component identification (Gentlemen please help...)
Discussion in 'General Electronics Chat' started by Kirat Patani, Jun 6, 2016.
  1. Kirat Patani
    Feb 29, 2016
    11
    I have a 2 logic modules and one of them seems to have gone bad... I have found what looks to be a shorted transistor on the PCB... But for the life of me I cannot seem to figure out the right part number for this... It looks to be TO-92 package made by National Semi and the part# I'm searching for is FE41099... But I seem to be having no luck with this... Could someone point me in the right direction please... I have a attached a pic of the component to simplify things... Your help is much appreciated.
  2. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,524
    There was a 2SC606 vhf tuner transistor in the past.
    Max.
  3. ISB123
    May 21, 2014
    1,240
    531
    Is it defective? Did you try measuring it with a multimeter?
  4. Kirat Patani
    Feb 29, 2016
    11
    @MaxHeadRoom
    From a quick google search 2SC606 dose not seem to be right part... Thanks for trying :)
    @ISB123
    Yes it is defective... The original transistor is burned/bubbled...
  5. ISB123
    May 21, 2014
    1,240
    531
    From what equipment did the transistor come off?​
  6. Kirat Patani
    Feb 29, 2016
    11
    @ISB123
    This is out of a Micro Switch Logic Module
  7. ISB123
    May 21, 2014
    1,240
    531
    Do you have schematics maybe?Or pictures of PCB where transistor used to be.
  8. mcgyvr
    Oct 15, 2009
    4,791
    976
    I'm with Max on this.. 606 NPN transistor
  9. Kirat Patani
    Feb 29, 2016
    11
    I do not have any schematics... Here is a pic not sure how much it will help..
  10. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,524
    Usually the 41099 is the manuf marking or date code.
    Max.
  11. Kirat Patani
    Feb 29, 2016
    11
    @mcgyvr
    correct me if I'm wrong... But from what google shows me is 2SC606 looks more like this...
  12. Kirat Patani
    Feb 29, 2016
    11
    @MaxHeadRoom
    I also just searched for 2SA606 and came across these can type transistors...
  13. Kirat Patani
    Feb 29, 2016
    11
    Just did a NTE search for 41099 and came across part# 4822-130-41099... NTE equivalent seems to be NTE108... maybe i should try my luck with this...??
  14. ISB123
    May 21, 2014
    1,240
    531
    Can you take more pictures of PCB so I can see the cap and resistor values.
  15. Kirat Patani
    Feb 29, 2016
    11
  16. mcgyvr
    Oct 15, 2009
    4,791
    976
    I think 41099 (4/10/99) is the data code..
    606 makes it an NPN transistor.. Probably anyone would be fine for this application..
    I didn't find the datasheet for the 2SC606 that max referenced but a description showed it to be a NPN transistor also.. Just the wrong package/case..
    I'd grab any NPN transistor I had laying around and just use that to start..
  17. ian field
    Distinguished Member
    Oct 27, 2012
    4,456
    792
    How much more PCB is out of shot? - it may be simple enough to hand trace the schematic.
  18. ISB123
    May 21, 2014
    1,240
    531
    It's 2sc2603?
