component ID help
Discussion in 'General Electronics Chat' started by ed williamsen, Nov 4, 2012.
  1. ed williamsen
    Nov 4, 2012
    trying to identify a component.
    I have what looks like a signal diode ( small glass envelope). It has color bands of yellow, yellow, white or possibly gray and finally yellow bands. Of course it is open and I need to replace it. It is in a base bais circuit in a engine tachometer used in a 1966 GM car. I want ot repair the unit rather than replace it. The board has two other similar components banded blue, green, brown. These both measure .3 ohms.
    Thanks in advance for any help!!
    ed Williamsen
  2. MrChips
    Oct 2, 2009
    12,633
    3,453
    It would be best for you to post a clear, well focused photograph of the board.
    ed williamsen likes this.
  3. Dodgydave
    Jun 22, 2012
    5,150
    769
    if it is a diode, it will probably be an OA91 germanium type of that year, or its a zener.
  4. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,386
  5. THE_RB
    Feb 11, 2008
    5,435
    1,305
    Old transistor engine tachos often used a mid voltage glass zener around 7v, as a crude "regulated voltage" for the monostable freq detector.
  6. ed williamsen
    Nov 4, 2012
    Hello thanks for the input.
    Ed Williamsen
