Component calculation
Chibesa
Joined Nov 23, 2015
I need help on how to calculate the component values for a bidirectional isolated dc-dc converter. I'm using a half bridge on the primary of the transformer and a current fed push-pull on the secondary...Any help rendered will be highly appreciated!
Chibesa
Joined Nov 23, 2015
That's the image showing the topology. But my task is to calculate the values of components like the capacitors,inductor, switch parameters etc. The voltage on the bus is 48V and the battery is 12V. I need help on the formulas to use to calculate these circuit parameters. Thank you!
