Compliment to relay
Discussion in 'Electronics Resources' started by Kenah, Jan 24, 2015.
  1. Kenah
    Jan 24, 2015
    What would be the compliment to a relay
    i.e. detects a higher voltage / current and outputs a 3.5-5v digital signal?
    Thanks for help
  2. ScottWang
    Aug 23, 2012
    4,924
    777
    What's the purpose of the relay?
    You may using a LM393 Or LM339 to detecting the Voltage and output a voltage, maybe you want to using the output voltage to drive a relay, if you do so then you should adding a bjt to drive the relay.
    Kenah likes this.
  3. Kenah
    Jan 24, 2015
    Thanks for this - and what, please, would detect the presence on a voltage / current?
  4. ScottWang
    Aug 23, 2012
    4,924
    777
    You need to specific how is the voltage and current, and describe more details about what you trying to do?
  5. MikeML
    Oct 2, 2009
    5,450
    1,066
    Look at a TL431
  6. wmodavis
    Oct 23, 2010
    737
    150
    In Boolean theory the complement is also referred to as the NOT function.
    Therefore based on logic to answer your question "What would be the compliment to a relay?" is NOT a relay.
  7. MaxHeadRoom
    Jul 18, 2013
    10,827
    2,495
    I think the OP meant Complement not compliment, subtle difference.
    So it could be all manner of solid state devices, transistor, mosfet, IC, etc?
    As asked, more info needed??
    Max.
  8. Chancepe
    Jan 29, 2015
    Consider adding a PTC fuse in the pack to prevent fires from short-circuits. Also, don't try to solder up a pack yourself. mcse The heat from soldering will damage the cell internals.
  9. sirch2
    Jan 21, 2013
    1,008
    351
    Sounds like a relay with a higher voltage coil, e.g. a relay designed with a 240v coil can switch 5V.
    However I am wondering about your use of the term "detects", perhaps you want a current transformer and a transistor to do the switching.
  10. MrChips
    Oct 2, 2009
    12,623
    3,451
    I still don't get the question.
    Would someone care to enlighten me?
  11. ScottWang
    Aug 23, 2012
    4,924
    777
    Not just you, I already asked the details in #4, but there is no response, does you think will this become a dead thread?
  12. wmodavis
    Oct 23, 2010
    737
    150
    The "?" in the OP would be suggestive of someone asking a question.
    However I have done a thorough analysis of the word and letter patterns and the evidence is conclusive.
    It is a mish-mash conglomeration of the same and the "?" is just a decoy.
  13. MrChips
    Oct 2, 2009
    12,623
    3,451
    So, in decoding the OP, I make the assumption that is an issue with the English language.
    So the OP is really asking, "How does one detect a high voltage/current and output a logic signal at 3.5-5V levels?"
    Thus the reference to a "compliment to a relay" is unimportant.
    The simple solution is to use an analog comparator such as LM311, LM2901, LM339, for example.
  14. wmodavis
    Oct 23, 2010
    737
    150
    With the mish-mash conglomeration whether due to language (likely) or other possible causes, your guesses, my guesses and anyone guesses on what was on the mind of the thread starter have more or less equal odds of passing within striking distance of the not so clear target. So guess away.
