Hello, new here and I have a complicated issue. Hang in there the explanation might take a while.
So I have 11 tvs/displays and 5 sources (2 cable boxes, gaming system, dvr, and a future PC server setup. All have hdmi cables. Each display has 2 cat5e and cat6 running to it from the "source" room. My plan is to have hdmi and ir over cat6 from each of the displays that will then go to a 5in 1out hdmi splitter with ir remote. Then from there each one will go to one of the 5 devices and each device will have a 1in 11out splitter (I archived 11 out by plugging a 1in 4out into a 1in 8out splitter making 11) now here is the issue. All of the 5in 1out splitters are identical and use the same remote and frequency. I was planning on using aux cables in the "source" room to connect all ir signals to their respect locations but the signals will get mixed at the shared cable boxes. I have bought several different types of ir emmiters but I can't get ANY of them to work. Only thing that works is an aux cable replacing the emmiter. I tested the emmiters with my front facing camera on my iPhone and all emmiters are sending the signal but no matter what combination I use I can't get them to work. I have tried different cable boxes, tried it on the splitter, tried a ir receiver on the back of the cable boxes and had the emmiter pointed at that receiver. Nothing will work!! It's driving me nuts. I don't care for solving the problem with the emmiters if there is an aux solution without them mixing signals. The next thing I will try is wiring a diode in the aux cable to hopefully prevent the signal from backtracking at the cable boxes. But voltage loss will probably be to big and deplete the ir signal. I'm running out of things to try.
