complex waveforms
Discussion in 'Homework Help' started by cjacobs, Dec 29, 2010.
  1. cjacobs
    Dec 8, 2010
    10
    Can somebody help please.
    I am trying to construct a complex waveform this formula.
    V=141.4sin240pit+28,3sin720pit+14.14sin(1200pit-69deg)
    Now i have tried to do it by hand but my fundamental wave dont make 1 cycle in 8.3 ms the way it should do.I dont know if i have used the formula correctly to obtain each plot. I assume you get the sin of 240pit(t will be different for each ms) and then multiply it with 141.4.Please can somebody shed some light.:confused:
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    If you have MS Excel or similar spreadsheet software you can give that a try.
    hgmjr
  3. Ron H
    Apr 14, 2005
    7,050
    657
    It's also easy to plot on a simulator such as LTspice.
  4. Georacer
    Nov 25, 2009
    5,151
    1,266
    Ron's picture says it all. If you want to do it yourself, any circuit simulation software is ideal. Matlab will also do. Do you have a copy?
  5. someonesdad
    Jul 7, 2009
    1,585
    141
    Here's a quick plot made with python/numpy/matplotlib:
    Code ( (Unknown Language)):
    1.
    2. from __future__ import division
    3. from pylab import *
    4. N, t0 = 200, 0.05
    5. t = arange(0, t0, t0/N)
    6. V = 141.4*sin(240*pi*t) + 28.3*sin(720*pi*t) + 14.14*sin(1200*pi*t - 69*pi/180)
    7. plot(t, V)
    8. savefig("a.png", dpi=75)
    9.
    If that's not what you're after, you'll need to learn to write your equations properly so that they're unambiguous.
      File size:
      24.6 KB
      21
