complex power flow
Discussion in 'Homework Help' started by Kayne, Jul 28, 2012.
  1. Kayne
    Thread Starter Active Member
    Mar 19, 2009
    105
    Hi all,
    I have been stuck where to start on a power flow question that has two interconnected voltage sources, which is in the attachment. Also in the attachment is the equation that I have been trying to use.
    Firstly i would like to know is this the correct equation I should be using to solve this? If so then i should be able to build a matrix to solve this question.
    What I would like to find out is
    i) the source complex power that are supplied and received (
    ii) the complex power loss in the line
    iii) which source receives or supplies the active and reactive power components.
    The questions variables are as followed
    Z=1+j7
    Y = 0.02-j0.14
    Polar
    v1=120 \angle -5
    v2=100 \angle 0
    Rect
    v1=119.54-j10.46
    v2=100+j0
    What I have done is solved
    i=V*Y
    i1 = 52.1-j970 A
    i2 = 114.6-j802.1 A
    now I use these values and solved for
    S=V*I
    Which gave me 27.96*10^3-j195.722*10^3 VA
    I would like to know if this is the correct way to go about solving this.
    Kayne
    • Q10.pdf
      File size:
      97.7 KB
      47
  2. mlog
    Member
    Feb 11, 2012
    276
    36
    Why do you have a current i1 and current i2? There is only one current between the two sources (unless you're trying to use superposition). The current will be the difference in the voltages divided by the impedance between the voltage sources.
  3. panic mode
    Oct 10, 2011
    1,330
    305
    your method makes no sense. when you write equation down, you are supposed to use it. you skip that and write random 'results'. if the Z-1+j7 Ohms, then your Y is correct. but there is no mention HOW you got V and what it's value is.
    also you post equation for current i and you never sow what that current is. instead of that, you show i1 and i2 (whatever that is). you never mention what they represent or how you obtained them. then you calculate S from V and I. what V and I? is I=i perhaps?
  4. Kayne
    Mar 19, 2009
    105
    Both of you are correct I really was struggling to understand what going on.
    So I have started again taking on your advice
    Variables are
     Z=1+j7
     Y=0.02-j0.14
    pol
     V1=120 \angle -5
     V2=100
    rec
     V1=119.54-j10.46
     V2=100
    Current in the circuit
     I=\frac{V1-V2}{Z}= -1.073-j2.945 A
    Complex power
    where I` is a complex number
    Sv1 = complex power in Voltage source 1
    Sv2 = complex power in Voltage source 2
     Sv1=\frac{V*I`}{2} = \frac{119.453-j10.46*-1.073-j2.945}{2}=-79.56-j170.43 kVA
    magitudeSv1  = 188.1 \angle -115
     Sv2=\frac{V*I`}{2} = \frac{100*-1.073-j2.945}{2}=-53.67-j147.26 kVA
    magitudeSv2  = 156 \angle -110
    So voltage source 1 is the supplying the load and voltage source 2 is receiving
    Power loss in the line = I^2*R
    Find Resistance
    R= mag(Z)*cos(Z)= 1
    PL=I^2*R=(-1.073-j2.945)^2*1=-7.52+j6.32 W
    Am I on the right track now with answering this question?
    Thank
  5. mlog
    Member
    Feb 11, 2012
    276
    36
    1. I got the same answer as you for the current.
    2. Why are you dividing the complex power of each source by 2?
    3. You are asked for the "complex power loss" for the line. Normally I think of power loss as resistive, but nevertheless, I think you could take the magnitude of the current, square it, and multiply it times the resistance and the reactance.
    For example, given the current you found, the magnitude is 3.135A. Squaring the magnitude and multiplying it times the resistance (1Ω) would give a line power loss of about 9.83 W. Do the same for the inductive reactance to find the VARs.
  6. hexram
    Feb 29, 2012
    8
    I certainly agree with mlog when questioning the division by 2 in the expression for S; complex power in any component in an electrical circuit is S = V I^*. It does not matter if the component considered is an active component (like a voltage source) or a passive component (like an impedance). As such, then, the answer for item ii) should be a complex number; if the circuit shown is a representation of a transmission line, for instance, then the impedance given corresponds to the line itself, and there is no reason to consider the loss in the line as just the real part of the total complex power. What I would say then is that S = I^2 Z because V = I Z and I I^* = I^2. Also, current in the circuit shown is just one item, and that is what I call I in my post.
