complex Number
Discussion in 'Math' started by micro1, Apr 26, 2015.
  1. micro1
    Feb 22, 2015
    53
    it is my solution true?
    Mod Comment: Made pic immediately visable.
      File size:
      302.7 KB
      1,417
  2. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    micro1 likes this.
  3. micro1
    Feb 22, 2015
    53
  4. Papabravo
    Feb 24, 2006
    10,340
    1,850
    If |A| and |C| were colinear then the difference in their arguments would be 180°.
    168.65° - (-71.34°) = 239.99°
    Also |B| and |C| do not make the same angle with the real axis.
    micro1 likes this.
  5. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    Ok, having a closer look, you are right.
    It is more common to use 16 ∠ 48.66° is stead of 16 ∠ -311.34°
    Bertus
    PS for me it is 40 years ago I had this stuff.
    micro1 likes this.
  6. studiot
    Nov 9, 2007
    5,005
    515
    micro1,
    What don't you understand about the replies?
    micro1 likes this.
  7. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Fine, turn it in and see what happens.
    micro1 likes this.
  8. joeyd999
    Jun 6, 2011
    2,756
    2,922
    @Papabravo, @bertus:
    You guys must be mind readers. I see a rough sketch of a graph of 3 vectors, A, B, and C followed by the question "Is my solution true?", but no assertion of which to determine the "truthfulness".
    Is it the relationship between A, B, and C that he is inquiring about? Or just, "given A, B, and C, is this a correct graphical representation?" Without such an assertion, the original question is meaningless.
    micro1 likes this.
  9. Papabravo
    Feb 24, 2006
    10,340
    1,850
    You'll get no argument from me on that score. I made an assertion based on my assumptions, and was expecting a meaningful response.
    micro1 likes this.
  10. WBahn
    Mar 31, 2012
    18,085
    4,917
    Solution to what?
    If you are trying to plot those three vectors, then you have them in the right quadrants, but I would not say that they are close enough to be scored "correct". Is your A vector, as drawn, closer to the real axis or the negative imaginary axis. Which should it be closer to?
    Similar question for your B vector.
    Your C vector looks close enough to be at least roughly correct.
    As already pointed out, your A and C vectors, as drawn, look to be collinear (allowing for the marked curvature in your C vector). Does that make sense?
    Also, you need to give an indication of scale. There is no way to tell if your vectors are the correct length because you give no scale on your axes.
    micro1 likes this.
