Completed Project Video
Discussion in 'The Projects Forum' started by torpedochief, May 15, 2010.
  1. torpedochief
    Thread Starter Senior Member
    Mar 30, 2008
    124
    6
  2. retched
    Dec 5, 2009
    5,201
    313
    That cannon fire sounds incredible. The whole thing looks, and sounds very, very good.
    Don-- good work. Its a piece of art. Something you should be VERY, VERY proud of.
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Nice, Don!
    Looks like the gun sound/flash/recoil get a bit out of sync though - perhaps you're not triggering them cleanly?
  4. retched
    Dec 5, 2009
    5,201
    313
    I noticed that earlier in the video, but I though it was me. When the firing occurs close to the camera, It looked, and sounded, right on.
  5. torpedochief
    Mar 30, 2008
    124
    6
    Thanks Guys,
    I am having trouble withthe sync. When I operate the TC sometimes the gun sound activates but they are no where near each other. I also have some more adjustments to make on the micro switch for the cannon. I took the model from 70 degress into 90 degrees outside. Maybe that had an effect. I know when you take your tank into the cold you should wait until the temp equalizes.
    Just a few tweeks and we'll have it down.
    Once again none of it would have been possible without this forum. THANKS!
    Don
    Hey when can we work on the sound system?...hehehehe
  6. retched
    Dec 5, 2009
    5,201
    313
    Get a lifesize tank and Ill fly down and install it. ;)
    The sound system sounded great. What more did you want to do?
  7. torpedochief
    Mar 30, 2008
    124
    6
  8. Audioguru
    Dec 20, 2007
    9,411
    896
    The motor sounds awful but the cannon sounds fantastic and very realistic.
  9. torpedochief
    Mar 30, 2008
    124
    6
    The recordings are actually taken from the few Panzers left. Suamar in France has the only running King Tiger, Germany and now the US and France have running Panther Ausf. D, and England has the only Tiger 1. Germany just refurbished a Jadgapanther and restored the 75 to firing condition. These tanks are really fun, and safe. They don't crash, or sink.
    Don
  10. Audioguru
    Dec 20, 2007
    9,411
    896
    So the recording sounds fantastic and very realistic because it is a recording of a real tank?
  11. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Audioguru,
    They are noisy beasties; lots of rattling and clanking. "Stealth" wasn't thought of until many years later.
    It would be very difficult to accurately reproduce the sound of the original tank from such a small model that's already crammed with lots of stuff.
  12. Audioguru
    Dec 20, 2007
    9,411
    896
    My little clock radio has a half-decent 3" speaker but I added my own audio amp and lots of bass boost so it plays anything extremely well when its volume control is turned down.
    When the volume is turned up then the bass boost is reduced so that the amplifier does not clip.
    My computer speakers have very high quality 3" speakers and reproduce the cannon sound very well.
    I cannot see the size of the model tank so I don't know if a half-decent 3" speaker will fit.
  13. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Is your little clock radio powered by AC?
    What is the voltage and power requirement of the audio amp circuit that you built?
    Don is pretty limited in what he can use, as everything in his tank is battery powered. The main battery (from what I understand of it) is 7.2v.
  14. Audioguru
    Dec 20, 2007
    9,411
    896
    My clock radio amplifier is an obsolete LM2896 bridged and bootstrapped amp that I built 35 years ago for my beach sound system.
    Its output is 3.6W at clipping into 4 ohms with a 7.2V supply.
    Most car radio amp ICs are bridged but don't work from a supply as low as 7.2V.
  15. torpedochief
    Mar 30, 2008
    124
    6
  16. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    So are you going to be helpful here, or just continue to be Scrooge-ish?
    If you're going to take the latter course of action, I will suggest to the moderators that they boot your ass out of here yet again, and I'm sure that they will gleefully follow up on it.
    You should put on your "Mr. Helpful" hat about now.
  17. Audioguru
    Dec 20, 2007
    9,411
    896
    I am sorry.
    I cannot recommend a modern medium power but low supply voltage amplifier IC when they are not made anymore.
