I worked with a kid once, he had ADHD and narcolepsy. One minute he was all over the place, and the next, he was sleeping...Don't know, lets see what other people think. I originally put them into alphabetical order. I think I have touch of OCD to go along with my ADD.
OCD = Obsessive Compulsive Disorder
ADD = Attention Deficit Disorder
A bad combination that.
If you think we should I'm game.
Introduction to options:example:
The whole option list should be wrapped with quotes.
Options are seperated by a semicolon
If an option has a value it is assigned with "equal to" mark. (option2)
If the value contains blanks or special characters it has to be wrapped with apostrophes. (option3)
If an option has more than one value they are seperated by a comma. (option4)
Description of options:
head
This option defines the first line as head, so the first row is shown as head of the table. If the table sould be sorted, the head is not sorted.
sort=1d,2,3
This defines the table to be sorted by column 1, then column 2, then column 3. The "d" after the first colum specifies the order: descending (default: ascending)
autonum=1
(equal to
autonum
autonum=a
autonum=A
Defines that a new first column containing a numbering should be inserted.
1 -> 1, 2, 3, 4, ... , 999, 1000, ....
a -> a, b, c, ... , aa, ab, ... , zz
A -> A, B, C, ... , AA, BB, ... , ZZ
autonumtitle=oneword
autonumtitle='long value with spaces'
Defines the title of the autonum-column. Can be left empty.
width=123px
width=45em
width=67%
Defines the width of the table.
Using the table=head option of table (quote this post to see), you get this, which sorts itself!OK, I opened your post #15 for editing using my moderator privileges. There is a straight line between each field.
Halloween decorations|tom66|11/3/2010
How do I generate that character?
Right now the topics are sorted alphabetically. I did it by hand .
Nice sorting routine....Using the table=head option of table (quote this post to see), you get this, which sorts itself!
It HATES one line tables, but if you add more with table=head;sort=3, it will autosort them by date. Right now, Just click on "Date Submitted" 3 times to sort by year, it sorts dates in all formats, year before slash, in middle, or at end, so if you keep clicking "Submitted", you'll see it re-order by month, day, year on each click until you get the sort you want.
Small steps, and you will eventually conquer the world. I liked that sorting routing.That will probably push us to change our date format.
