Complete PCB fabrication shops?
Discussion in 'General Electronics Chat' started by wayneh, Sep 7, 2016.
  1. wayneh
    Thread Starter Expert
    Sep 9, 2010
    12,388
    3,244
    There's a lot of information in the forums here about where to get PCBs made. I'm wondering about completed boards with the components placed and soldered.
    Where can you get that done and what would you expect to pay? (Assume no unusual parts.) I know I've seen it mentioned here from time to time but has anyone compiled a list? Any favorite shops you have experience with?
    References for PCB shops:
    http://forum.allaboutcircuits.com/blog/pcb-board-houses.475/#comment-1198
    http://forum.allaboutcircuits.com/t...ole-plating-solder-masks-and-low-cost.105214/
    http://forum.allaboutcircuits.com/threads/pcb-outsourcing.112524/#post-871195
  2. joeyd999
    Jun 6, 2011
    2,757
    2,930
    I use Advanced Circuits for prototype boards, but they also do assembly with as short as a 1 day turn. They'll quote a job for you.
  3. wayneh
    Sep 9, 2010
    12,388
    3,244
    Ballpark cost for a small (5cm square) board? 1-10 pieces
  4. mcgyvr
    Oct 15, 2009
    4,791
    976
  5. GopherT
    Nov 23, 2012
    6,310
    4,031
    The two places I looked at recently had a $1000+ minimum for populated board projects.
    wayneh likes this.
  6. wayneh
    Sep 9, 2010
    12,388
    3,244
    Well that would explain why there's not much talk of it here in the forum. Not bad for industrial prototypes but not what a typical hobbyist is looking for.
  7. joeyd999
    Jun 6, 2011
    2,757
    2,930
    If you consider the capital investment, support staff, and overhead required to build random assemblies, plus the economic requirement to run continuously at close to 100% utilization (thus to effectively absorb the overhead), very short "hobbyist" runs are necessarily not amenable to such things.
  8. RichardO
    May 4, 2013
    1,341
    429
    A friend has used this company and was satisfied:
    https://macrofab.com/
    They are a turnkey operation meaning that they order the PCB and all of the parts and then assemble them. They do not do through hole parts.
  9. mcgyvr
    Oct 15, 2009
    4,791
    976
    Try itead.. I would bet money they aren't anywhere near that..
    They are targeted towards hobbyists..
