complete design by using pic micro
Discussion in 'General Electronics Chat' started by karas, Oct 4, 2011.
  1. karas
    Thread Starter Active Member
    Sep 8, 2011
    127
    can some one help me send me complete project done by using pic micro. like power supply using pic to control pwm, can send me project include codes i like to learn pic microcontroller
    thanks
  2. Dyslexicbloke
    Sep 4, 2010
    420
    19
    Starting with a power supply may be a bad idea ... The subject is huge in its own right.
    I am not suggesting it cant be done, in fact it is regularly done, just not by beginners.
    If you chose something achievable and start with a pre built development board you will learn much faster.
    Once you have a project working you can set about replicating it from scratch on your own board.
    Controlling RC servos to make moving projects is fun ...
    (But that just me, I like to see a tangible result when I am learning)
    You can do almost anything with a uP but you are likely to get frustrated and disheartened if you try and start with something too complex.
    The likely result of building a power supply with no previous experience is lots of smoke and significant danger.
    You also won't get any advice on this board about high voltage based projects, with good reason. IE it could kill you.
    Al
    karas likes this.
  3. karas
    Sep 8, 2011
    127
    can you please send me link with this simple circuits
    to do it and learn from it
  4. t06afre
    May 11, 2009
    5,939
    1,222
    Which PIC micro do you plan to use. Will you be using assembler, C or basic
    karas likes this.
  5. TAKYMOUNIR
    Jun 23, 2008
    351
    i will use PIC18F45K20 and i know c++ and assemly language
  6. karas
    Sep 8, 2011
    127
    please if some one send me link with some simple circuit done by pic micro
    i need to learn pic micro
    thanks
  7. nerdegutta
    Dec 15, 2009
    2,565
    806
    Check out this link.
  8. tom66
    May 9, 2009
    2,613
    214
    You will learn more if you actually do your coursework yourself.
    Have you attempted to make basic circuits and programs that flash an LED, for example?
    karas likes this.
  9. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,386
    karas likes this.
  10. nerdegutta
    Dec 15, 2009
    2,565
    806
    karas likes this.
