compilation in VHDL
Discussion in 'Programmer's Corner' started by Infinity1, May 22, 2009.
  1. Infinity1
    Jan 11, 2009
    16
    Hello Everyone
    I have written this code,the code is to convert binary to bcd and to display the result in two(for temperature) 7segment, but the problem is that the compilation fails, maybe someone can explain me what's wrong with my code and how can i fix it
    thank's
    here is the code:
    library IEEE;
    use IEEE.std_logic_1164.all;
    use IEEE.std_logic_unsigned.all;
    entity binbcd is
    port (
    Bin_in: in STD_LOGIC_VECTOR (7 downto 0);--Binary Input
    bcd_in_1 :in std_logic_vector (3 downto 0);
    bcd_in_2 :in std_logic_vector (3 downto 0);
    hex0 :eek:ut std_logic_vector (6 downto 0);--output name for 7segment display in DE2
    hex1 :eek:ut std_logic_vector(6 downto 0);
    Bcd_out: out STD_LOGIC_VECTOR (9 downto 0)--Bcd Output
    end binbcd;
    architecture binbcd_arch of binbcd is
    alias HEX_1 :std_logic_vector(3 downto 0) is Bin_in(3 downto 0);
    alias HEX_2 :std_logic_vector(3 downto 0) is Bin_in(7 downto 4);
    begin
    bcd1: process(Bin_in)
    variable z: STD_LOGIC_VECTOR (17 downto 0);
    begin
    for i in 0 to 17 loop
    z(i) := '0';
    end loop;
    z(10 downto 3) := Bin_in;
    for i in 0 to 4 loop
    if z(11 downto 8) > 4 then
    z(11 downto 8) := z(11 downto 8) + 3;
    end if;
    if z(15 downto 12) > 4 then
    z(15 downto 12) := z(15 downto 12) + 3;
    end if;
    z(17 downto 1) := z(16 downto 0);
    end loop;
    Bcd_out <= z(17 downto 8);
    end process bcd1;
    end binbcd_arch;
    architecture behave of seven_seg is
    begin
    process(HEX_1,HEX_2,hex0,hex1) --architecture behave of seven_seg is
    begin
    with HEX_1 select --(MSB) GFEDCBA (LSB)
    hex0<= "1000000" when "0000", --show 0 at the display
    "1111001" when "0001", --show 1 at the display
    "0100100" when "0010", --show 2 at the display
    "0110000" when "0011", --show 3 at the display
    "0011001" when "0100", --show 4 at the display
    "0010010" when "0101", --show 5 at the display
    "0000011" when "0110", --show 6 at the display
    "1111000" when "0111", --show 7 at the display
    "0000000" when "1000", --show 8 at the display
    "0011000" when "1001", --show 9 at the display
    "1111111" when others;
    with HEX_2 select --(MSB) GFEDCBA (LSB)
    hex1<= "1000000" when "0000", --show 0 at the display
    end behave;
  2. dsp_redux
    Apr 11, 2009
    182
    5
    Maybe you could give use what the error message is?
