Compensating diodes used on push pull amplifier
Discussion in 'Homework Help' started by Saviour Muscat, Sep 23, 2014.
  1. Saviour Muscat
    Sep 19, 2014
    82
    Hello
    Hope you are all good,
    Can someone explain how does the compensating diodes work during the positive and negative half cycles input signals of push pull amplifier?
    Thanks and regards
    SM
  2. Jony130
    Feb 17, 2009
    3,993
    1,116
  3. Saviour Muscat
    Sep 19, 2014
    82
    I am confused , it is a little bit hard to understand, the circuit that I am studying don't have a dual supply but a single supply as the image attached. I need how the circuit works when given an ac signal(during negative and positive half cycles). I don't need diagrams but refer to the image attached. I hope for your understanding.
    thanks
  4. KL7AJ
    Nov 4, 2008
    2,047
    295
    Those aren't compensating diodes; they're forward bias diodes.
    Saviour Muscat likes this.
  5. Jony130
    Feb 17, 2009
    3,993
    1,116
    Well, but the circuit work almost exactly the same. Without any input signal both transistor conduct because of this diodes in the circuit.
    For positive half cycles upper transistor deliver current the the load by charging capacitor. And for negative half cycles lower transistor discharge capacitor. And this is why we have a negative voltage at load.
    But what if we mount these diode on the same heat sink as a output transistor?
    ramon22 and Saviour Muscat like this.
  6. Saviour Muscat
    Sep 19, 2014
    82
    I didn't expected a good reply like this ,I understood completely many thanks. I hope this is the last question in this thread.
    How the bias diodes (not compensating diodes) bias the transistor more 0.6V to eliminate crossover distortion? Especially during positive and negative half cycles.
    Many thanks to everyone for your support?
  7. #12
    Nov 30, 2010
    16,704
    7,354
  8. Jony130
    Feb 17, 2009
    3,993
    1,116
    Pleas notice that BJT's need at least 0.5V to 0.7V of forward base-emitter bias voltage before they will go into conduction. In our push pull amplifier both of the transistors will be nonconducting of OFF, when input signal is in range +/- 0.5V. And this form's a "deadzone" in the input and produces crossover distortion in the output.
    So, to avoid this crossover distortion, it is necessary to add a small amount of forward bias to take the BJT's in the verge of conduction or slightly beyond. And this is why we add this two diode's into the circuit. The job for the diodes is to provide a small amount of bias voltage, to take the BJT's in the verge of conduction or slightly beyond. And this is how we eliminate this "deadzone".
    Now even with no input signal both transistor conducting the small amount of DC current.
    And this help as eliminate the crossover distortion.
    Also try read this
    http://forum.allaboutcircuits.com/threads/sine-wave-distortion.90332/ (post 16 )
  9. alfacliff
    Dec 13, 2013
    2,449
    428
    the temprature charistics of the diodes compensates for heat in the transistors, when the transistors get hot, the diodes do too, reducing bias, and reducing current.
    if you measure the foreward drop across a diode, it changes with heat.
  10. MrChips
    Oct 2, 2009
    12,642
    3,457
    Jony130 explains it very well.
    In a class B amplifier only one of the two transistors is active. This results in cross-over distortion.
    In a class AB amplifer you want the two transistors to start sharing the load current at cross-over. Hence the transistors are biased into conduction with the aid of the two bias diodes.
  11. #12
    Nov 30, 2010
    16,704
    7,354
    My post #7 details how to adjust the current through the diodes to minimize the dead zone. Attaching the diodes to the heat sink of the power transistors helps the voltage across the diodes stay equal to the voltage you want from base to base. I would also like to say I've never seen this circuit without at least a few tenths of an ohm in series with each emitter, but that's getting into fine details about temperature tracking.
  12. Saviour Muscat
    Sep 19, 2014
    82
    Thank you very much for your support, yesterday I was at work I can't reply the same day sorry
    I tried to understand the operating principle with your help and I went to conclusion aided with the picture attached.
    I marked in red in the picture with the voltages without the input signal applied in the circuit, As I concluded is that the two transistors are forward bias by 0.6V as I calculated in red.
    Finally I marked in green with the input signal applied of 2V peak to peak to the circuit. I understood that during the positive half cycle, the signal can only pass through the upper diode only and this produces a voltage drop(or superimposed) of 11.6V(10+0.6+1) with respect to ground and this voltage is fed to the upper transistor then if you subtract the input voltage of 11.6V by 10V(the voltage between the two transistors) the result is that the upper transistor has an input bias 0f 1.6V .
    During the negative half cycle the signal passes only through the lower diode and produces a voltage drop (or superimposed) of 8.4V(10-0.6-1) and this voltage is fed to the lower transistor. then if you subtract the input voltage of 10V by 8.4V the result is that the lower transistor is biased by 1.6V.
    I am not 100% sure what I'm concluded, please kindly can you confirm if I am correct? or otherwise make a correction what I said wrong.
    Your support is much appreciated!
    Thanks and good day
    Saviour Muscat
  13. MrChips
    Oct 2, 2009
    12,642
    3,457
    You have the right idea. However you cannot analyze the circuit by considering voltages alone. You have to also consider currents.
    Each transistor is configured as an emitter follower (common collector) amplifier. This produces current gain and unity voltage gain.
    The output current flows through the load. Hence the impendance of the load must also be considered. To analyze the circuit, one calculates the base current. The emitter current is the base current x (1 + beta). Hence this produces current gain. Because this output stage is the power stage, one is interested in the output power. Hence one calculates the power delivered to the load.
  14. Jony130
    Feb 17, 2009
    3,993
    1,116
    Hi, I encourage you to read this very carefully.
    http://forum.allaboutcircuits.com/threads/voltage-divider-bias.71104/#post-494950
    http://forum.allaboutcircuits.com/threads/class-b-push-pull-amplifier.85631/#post-615183
    As for your circuit. Without the input signal voltage at T1 base is equal to 10.6V and 9.4V for T2.
    Output capacitor is charge to 10V and input cap is charged to 10V also.
    Id1 = Id2 = (20V - 2Vd)/(R1 + R2) = 18.8V/7.8K = 2.41mA (I ignore the base current).
    Now let as apply the input signal (2Vpp= peak to peak) to the circuit.
    The input signal "modulates" the DC voltage and currents in the circuit in the "rhythm" of AC input voltage.
    During the positive half cycle input DC voltage rise from 10V to 12V and back to 10V in the "rhythm" of AC input voltage.
    T1 base become more positive, D1 and R1 current decreases but D2 and R2 current increasing.
    T1 base current comes from 20V battery and R1 resistor. Input source current flow in the path:
    plus Vin--->Cin--->D2--->R1--->GND--->minus Vin.
    And the voltage across load resistor is equal to
    Vload = Ve1 - V_Cout = 11.95 - 10V = +1.95V
    For negative half cycle we have very similarity situation but this time T2 base becomes more negative, D2 and R2 currents decreases but R1 and D1 current increase. And Vin source current is flow in the path:
    plus Vin ---> minus_20V supply--through 20V supply--plus 20V supply--->R1--->D1--->minus Vin.
    And the output voltage is equal to Vload = Ve - V_Cout = 8.05V - 10V = -1.95V
    vol_, ramon22 and Saviour Muscat like this.
  15. Saviour Muscat
    Sep 19, 2014
    82
    Thank you for the detailed explanation it was what I expected
    My last questions
  16. Jony130
    Feb 17, 2009
    3,993
    1,116
    Yes, of course
    Vin--->Cin--->D2--->R2--->GND--->minus Vin
    Why? And I forgot about Cin.
    How about this one ?
    plus 20V --->R1--->D1--->Cin--->Vin--->gnd (minus 20V)
    Yes, you are right, I simply assumed this value. If you want to know the exact value you need to measure it in real circuit.
  17. Saviour Muscat
    Sep 19, 2014
    82
    Many thanks to all people involved especially Jony130
