Compatible Connector For CD Burner
Discussion in 'Computing and Networks' started by Glenn Holland, Feb 11, 2016.
  1. Glenn Holland
    Dec 26, 2014
    359
    114
    I have a 1999 vintage CD burner that has a DB25 pin connector. However my newer computer has just USB ports.
    Is there an interfacing connector between DB25 and USB or is my burner obsolete and a 5 LB. paper weight?
  2. shteii01
    Feb 19, 2010
    3,516
    515
    Is that external cd burner?
    If it is external, then you could take it out of the case and it should be just IDE/PATA interface (40 pin connector), then just use PATA connector on the motherboard.
    Alternatively, there are interface cards that add older serial ports to pc. There are might be usb to db25 cables too, I have not looked for one.
  3. Ramussons
    May 3, 2013
    562
    92
  4. BReeves
    Member
    Nov 24, 2012
    412
    64
    I wouldn't spend anything to try and make that old drive work. As hard as it is to suck it up, sometimes you just have to cut your losses and buy new equipment. Odds are pretty good that even if you get it plugged in the software won't work.
  5. tom_s
    Member
    Jun 27, 2014
    287
    342
    one of these you need. provided the drive still works
    usb2/ide/sata adaptor
    edit: people still using these? (optical media drives)
  6. shteii01
    Feb 19, 2010
    3,516
    515
    The trouble with that one is that cd drive still need power so you are going to crack open the pc case to get to power cable/connector and once pc case is open, well, just use the power and the ribbon cable to hook up cd drive to motherboard.
  7. shteii01
    Feb 19, 2010
    3,516
    515
    Hey Glen, this reminded me. I still have external modem, I bought it new back in 1998/99. It has db25 connector on the modem, but I plug it into db9 connector on the pc. Meaning that the cable I use for it had db25 on one end, db9 on the other end. So the question is: Do you really need db25 on the pc? You might just need regular serial port on the pc that has db9 connector.
    In my case. The mobo I have does not have serial port (db9 or db25). But it does have a serial header on the motherboard, so what I did is that I bought a ribbon cable with the bracket and db9 connector, installed it and now I have my modem hooked up to pc, it work fine since I have sent faxes using it.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16812200516
    In conclusion.
    Check if your mobo has serial header.
    Check if you can use db9 to db25 cable.
  8. shteii01
    Feb 19, 2010
    3,516
    515
  9. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    I have seen drives with separate cards to drive them.
    Some indeed had the 25 pins D connector.
    They could be a version of an SCSI interface.
    See here for more info:
    http://rajblogroom.blogspot.nl/2011/04/scsi.html
    http://superuser.com/questions/664983/what-types-of-scsi-connectors-are-these
    There also have been the zip and jaz drives from iomega:
    https://en.wikipedia.org/wiki/Iomega_Zip_drive
    https://en.wikipedia.org/wiki/Iomega_Jaz_drive
    There where types of them that used the parallel port for the communication.
    Bertus
  10. Ramussons
    May 3, 2013
    562
    92
    I'm still using these as and when required :D
  11. MrSoftware
    Oct 29, 2013
    545
    133
    It's most likely a SCSI interface. Most (all?) CD recorders from back then used SCSI interfaces. So you would most likely need a SCSI controller, a good SCSI cable and a terminator or two depending on if the CD recorder and SCSI controller are self terminating. And even then there's no guarantee that it would work well with modern software. Google or post the brand and model and see what turns up.
    Are you trying to make it work for fun, or do you really need to use it for something? Modern CD+DVD burners are under $20 including shipping here in the USA, I imagine they're pretty cheap in most other parts of the world too.
  12. tom_s
    Member
    Jun 27, 2014
    287
    342
    same here around $25-30AUD
