Compatability of USB port with atmega8L
Discussion in 'Embedded Systems and Microcontrollers' started by ammayi, Sep 25, 2010.
  1. ammayi
    Sep 17, 2010
    Hi, i am a bit confused with connecting a usb port to atmega8L. Many websites say that usb port can't be used with atmega8L. Is this through? if we can't use usb port, what is the alternative??
  2. retched
    Dec 5, 2009
    5,201
    313
    The atmega8L is a 3.3v device.
    USB is 5v.
    You would need a separate chip to handle the usb communications or a level shifter IC, then you could bit-bang.
    Save yourself a ton of headaches and get a uC with on-board USB.. There are many to choose from.
