Comparison of processing power
Discussion in 'Computing and Networks' started by LDC3, Aug 6, 2013.
  1. LDC3
    Thread Starter Active Member
    Apr 27, 2013
    920
    160
    I'm just asking, so it not vital.
    I would like to know how the processing power to today's desktops with Intel (or AMD) chips compare to the original Cray Supercomputer. I know they cannot be directly compared since they would need to run the same benchmark program. Probably the only thing that can be directly compared is adding an array of numbers (from memory, without cache). Even a educated guess within an order of magnitude would be close enough. Thanks.
  2. LDC3
    Apr 27, 2013
    920
    160
    I did some searching and found out that even smart phones :eek: can calculate faster than the original Cray Supercomputer.
  3. mcgyvr
    Oct 15, 2009
    4,791
    976
    So can a digital watch or simple calculator or kids toy or anything else made in the last 10+ years..
  4. LDC3
    Apr 27, 2013
    920
    160
    I wouldn't think so since you need at least a 1GHz clock, and most toys (except game systems) are not even close to that. Watches don't need that type of processing power.
