Comparing two circuits for amplifying a signal to turn on LEDs (NPN vs PNP transistors)
Discussion in 'Analog & Mixed-Signal Design' started by seanspotatobusiness, Sep 28, 2016.
  1. seanspotatobusiness
    Sep 17, 2016
    32
    Hi, I have two circuit diagrams. One circuit someone else designed using two NPN and one PNP transistors and it amplifies a signal to fade on an arrangement of LEDs. I changed it so the values of the resistors is probably no longer suitable. I don't know why they used a PNP transistor instead of using three NPN transistors so I drew the second circuit diagram which I think would do the same thing but I don't know enough about electronics to be confident. Can someone else advise why to use a PNP transistor?
  2. AlbertHall
    Jun 4, 2014
    2,266
    448
    In the circuit with the PNP transistor, when at least one of the inputs is at 2.3V the PNP transistor will be turned fully on and its collector will be within 0.5V of the 15V supply.
    In the circuit with only NPN transistors, from the inputs at 2.3V you will lose at least three times a diode forward voltage (input diode plus two base emitter voltages) so the maximum voltage at the emitter of the second transistor will be 0.2V! This is not enough to turn on the third transistor at all. It won't work.
  3. seanspotatobusiness
    Sep 17, 2016
    32
    Hi AlbertHall. Thanks but I'm not sure I understand. I thought I had organised the NPN transistors in a Darlington arrangement so they sequentially amplify the signal? Did I screw it up? I guess I still don't understand transistors as well as I had thought.
  4. AlbertHall
    Jun 4, 2014
    2,266
    448
    They are connected as a darlington pair but you are taking the output from the emitter and so the output voltage will be less than the input, though more current is available.
  5. #12
    Nov 30, 2010
    16,693
    7,331
    The way I calculate the second circuit, the voltage on the capacitor will never exceed 0.5 volts. Phooey. No light. The third transistor never comes on.
    The first circuit is what I call a double invert or a Sziklai Darlington. That one will apply almost all the 15 volts to the 5k resistor feeding the capacitor. Bingo. Let there be light!
    Then we get to the 10 ohm resistors. Not smart to allow so much credence to LED specifications as to expect them all to be 2.90 volts. You are allowing 0.2 volts for the resistor and it should be at least 10% of the power supply. You need to take out one LED in each string and adjust the resistor to 180 ohms.
    Then check the current and see if 180 ohms will keep the current down to the safe level for the LEDs.
    atferrari likes this.
  6. seanspotatobusiness
    Sep 17, 2016
    32
    Would changing the values of or removing any of the resistors make the first circuit work?
    I don't actually know the forward voltage of the LEDs I want to use yet but I guess I can subtract one in series and add another row in parallel and then use a higher value of resistor. Thanks.
  7. AlbertHall
    Jun 4, 2014
    2,266
    448
    The first circuit works (except, as noted, the LEDs and their resistors).
    If you meant the second circuit then, no, changing resistor values will not make it work.
  8. #12
    Nov 30, 2010
    16,693
    7,331
    Why do you have that capacitor in there? Without that, you need 1200 ohms between the second and third transistor.
    With the capacitor, you are creating a 1/2 second delay and starving the third transistor of current with 10,000 ohms.
    Why? If you want a delay, you should install it between transistor 1 and transistor 2.
  9. seanspotatobusiness
    Sep 17, 2016
    32
    Yes, I meant the second circuit! I made some changes so now it looks like this:
    According to this circuit simulation, it should work like this: http://everycircuit.com/circuit/6159582916771840
    The capacitor is meant to make the light fade on and off.
  10. AlbertHall
    Jun 4, 2014
    2,266
    448
    Your simulation does not include the diode at the input. Try it with that diode in place and see what happens.
  11. Alec_t
    Sep 17, 2013
    5,972
    1,135
    There is also the matter of the voltage drop across the 1k resistors. This is significant even if you assume an optimistic current gain of ~100 for the transistors.
  12. #12
    Nov 30, 2010
    16,693
    7,331
    After being told 4 times that three base-emitter junctions and a diode in series with 2.3 volts won't work, you insist on using that configuration.
    panic mode likes this.
  13. seanspotatobusiness
    Sep 17, 2016
    32
    I only insist on understanding why it won't work. I want to understand the circuits I'm using. I want to see how and why it fails.
  14. AlbertHall
    Jun 4, 2014
    2,266
    448
    Each diode or base emitter junction needs 0.6V to 0.7V to make it conduct. Your circuit has a diode and three base emitter juntions with just 2.3V available. That's not enough voltage to make them all conduct.
    Put the input diode in your simulation and look at the voltages.
  15. seanspotatobusiness
    Sep 17, 2016
    32
    I did that and indeed, it did not work! However, I measured my PIR sensor outputs and they are 3.3 V. I also have some diodes with a voltage drop of 0.2 V. I will probably be using the PNP version anyway, What I don't understand is why adding more transistors in Darlington pairs causes the final output to be too low when the whole point of Darlington pairs to amplify a signal, not absorb or block it? How do you use a Darlington pair to actually do what it's supposed to do?
  16. crutschow
    Mar 14, 2008
    13,498
    3,374
    A Darlington pair amplifies current, not voltage.
    It actually has an AC voltage gain of slightly less than one.
    But to turn on (bias) a silicon transistor requires about 0.7V per transistor, so for three transistors in a Darlington triple, 0.7V *3 = 2.1V bias is required to turn them on.
    Don't confuse AC gain with DC bias requirements.
    They are two different animals.
    You have to satisfy the DC bias requirements before you get gain.
  17. #12
    Nov 30, 2010
    16,693
    7,331
    I'll do the math for you:
    0.6V + 0.6V + 0.6V + 0.6V = 2.4V
    You need 2.4 volts just for the silicon with nothing left over for current gain.
    2.4V is more than 2.3 volts.
    Now you've changed the specification to 3.3 volts input and a 0.2 volt diode.
    Now you can get 1.3 volts across the last 1k resistor for a current of 1.3 ma.
    Using a transistor for a switch provides a gain of 10 to make it switch hard, so you can efficiently supply 13ma.
    You want 6 strings of 4 LEDs which require 120 ma
    120ma is more than 13 ma.
    Would you like to try modifying the second circuit, again? Or would you like to switch to the other circuit?
    Your choice.
  18. crutschow
    Mar 14, 2008
    13,498
    3,374
    Albert E supposedly said “The definition of insanity is doing the same thing over and over again, but expecting different results”.
    Are we getting there? :rolleyes:
  19. hobbyist
    Distinguished Member
    Aug 10, 2008
    773
    62
    There is the issue with voltage drops across all the diode junctions in series, so analyzing this circuit it shouldn't work,, so that was my conclusion as well , ,,,,untill I built it,,,,,,,well this video shows the rest of the story.
  20. seanspotatobusiness
    Sep 17, 2016
    32
    Thanks, I get it now. But how does the PNP transistor get around this? Is it because it's tapping into the 15 V to satisfy the bias?
    I'm done with the second circuit! I'm sorry for taking so long to get it. The first circuit was meant to power four rows of three LEDs in series but my power supply is actually 15 V so I intend to power five or six rows of four or five LEDs depending on what their Vf turns out to be. I've changed my simulation to the PNP circuit and no matter where I put the capacitor, they only way it fades on and off is I use a huge capacitor. http://everycircuit.com/circuit/6159582916771840
    Incidentally, is the 10 K resistor needed? When I change the value in the simulation or even remove it completely, it seems to have no effect on the function.
    Thanks for doing this video. Do you know how much current is passing through the LEDs? I think if you add more rows of LEDs there will not be enough current to make them light up very much.
