Comparing schematic and PCB design
Discussion in 'General Electronics Chat' started by RG23, Jun 30, 2015.
  1. RG23
    Thread Starter Active Member
    Dec 6, 2010
    301
    I have multiple PCB files all related to the same schematic but not all are the same.
    How to confirm which PCB design is corresponding to the actual schematic?
  2. dl324
    Distinguished Member
    Mar 30, 2015
    3,375
    651
    Do the boards and schematic have a revision number? They should...
    If no revision info on the board, visually inspect (I know it could be tedious) and compare differences.
  3. R!f@@
    Apr 2, 2009
    8,785
    771
    What PCB program ?
  4. RG23
    Dec 6, 2010
    301
    @what PCB program ?
    Its Altium schematic and pcb designer
    There is no revision number
  5. crutschow
    Mar 14, 2008
    13,472
    3,359
    Compare the boards to see if you can spot the physical differences in the layout or traces.
    You might want to print the layers on clear film so you can overlay them for ease of comparison.
    Once you spot the differences, then you should be able to determine which one corresponds to the schematic.
    RichardO likes this.
  6. JWHassler
    Member
    Sep 25, 2013
    204
    34
    PCB layouts can be visibly different and yet still implement the same schematic.
    Look at the time-stamps of the PCB-files as a first cut.
  7. djsfantasi
    Apr 11, 2010
    2,899
    870
    As mentioned, PCB layouts can be visibly different, yet implement the same schematic. Take a look at these two PCB board designs. They are designed from the same schematic. (Ignore the strip in the second picture)
  8. ErnieM
    Apr 24, 2011
    7,434
    1,625
    Files will have a time and date of creation. Typically the most recent files the most current version.
  9. Roderick Young
    Member
    Feb 22, 2015
    408
    168
    One layout has a 4.7k SIP (resistor network in one package), and the other has separate 4.7k resistors. Check the schematic to see which one you want.
  10. pwdixon
    Member
    Oct 11, 2012
    488
    56
    That was an example of the same schematic different layout, I don't think it was the circuit the OP was referring to.
  11. dl324
    Mar 30, 2015
    3,375
    651
    I would point out that there is no guarantee that the most recent version of the PCB file will correspond to the most recent version of the schematic file. Either could be revised independently. For example, in Eagle schematic changes can cause PCB routes to be removed; but I don't have to save the changed PCB. In that case, latest PCB does not correspond to latest schematic.
  12. nigelwright7557
    May 10, 2008
    488
    71
    I always put the filename of the pcb on the pcb so I don't get mixed up.
  13. cmartinez
    Jan 17, 2007
    3,696
    2,749
    I'd compare them using two simple approaches:
    1. Component match and quantity
    2. Number of nodes and matching interconnects
  14. Stuntman
    Mar 28, 2011
    189
    50
    Can you find the project file? That should let you know which PCB files are associated with that schematic.
    If you wanted, you could make a new project, add the "correct" schematic file, then all the PCB files you think may be associated.
    Open the schematic, under the Design tab, you can update each of the PCB files with the schematic on hand. Depending on your settings, you should be prompted of all the changes without actually having to make them. The one with no changes (or simply adding rooms or other garbage) should be ready to roll.... or you may find one that can be easily modified to your needs.
  15. djsfantasi
    Apr 11, 2010
    2,899
    870
    Ex
    Exactly. I was reinforcing @JWHassler's point. There is no expectation of a one to one relationship
