Comparing Photodiode and Phototransistor characteristics
Discussion in 'General Electronics Chat' started by Sensacell, Sep 18, 2014.
  1. Sensacell
    Jun 19, 2012
    1,184
    277
    I am working on a product requiring a photo sensor to detect white light, I need the largest possible dynamic range (1000:1 light levels) at the minimum cost.
    Response time: 200 us rise/fall
    Photo-conductive operation- (needs to sink current in proportion to light levels)
    Long term / temp stability not required, device will autocal for every measurement.
    No need for good linearity, I am not building a measuring device, just a lights on/off detector, with a large range of potential light intensities.
    Looking at the range of options, phototransistors seem to typically have a poor ratio of dark current to light current, but tend to be cheaper.
    Photodiodes seem to have a better ratio of dark/light currents and are fast, but the parts are MUCH more expensive.
    Are there any tricks to getting the wide dynamic range I seek? As cheap as possible?
  2. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
  3. Sensacell
    Jun 19, 2012
    1,184
    277
  4. takao21203
    Distinguished Member
    Apr 28, 2012
    3,578
    463
    BPW34 is not that expensive
  5. ian field
    Oct 27, 2012
    4,459
    792
    Photodiodes (can be) very fast but are not too sensitive - Phototransistors have gain which makes them more sensitive, but they're slower.
    Cd-S LDRs are the easiest to interface, and are the closest match to the human eye response curve - but they're *REALLY* slow, and I'm not too sure about RoHS compliance (Cadmium is *VERY* toxic!).
  6. Sensacell
    Jun 19, 2012
    1,184
    277
    Thanks all for your feedback, I will be experimenting with a bunch of sample parts, both photodiodes and transistors.
    I have a feeling the photodiode is going to be the winner.
  7. ronv
    Nov 12, 2008
    3,403
    1,477
    You don't state the light levels, but even so you should be able to develop a signal from 10 mv to 10 volts with a photo diode easily enough.
