Comparing 4 analogue signals
Discussion in 'Embedded Systems and Microcontrollers' started by Hliu, Nov 4, 2008.
  1. Hliu
    Nov 4, 2008
    Hi, I'm a PIC newbie/hobbyist, and I'm currently doing a project that requires comparison of 4 voltage levels ranging from ~1v - 5v. So I was wondering if it can be done by using PICs and programming, specifically the PIC16F84A. If it's not possible then can someone recommend me a way to go about it?
    Thanks in advance.
  2. mik3
    Feb 4, 2008
    4,846
    63
    With this PIC you cant do it because it has not built-in ADC. You can connect external ADCs but is easier to work with a PIC with built-in ADC like the PIC16819. Its not the only one, you can search for other PICs at www.microchip.com
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    You can also use a quad voltage comparator, although circuit and signal details would help.
  4. gvr_p
    Nov 5, 2008
    6
    better use another member from PIC family better PIC16F72 which has built in ADC
