Hi, Im designing a battery powered transmitter that detects the position of a valve. The valve will remain in the same position for the majority of the time, therefore I wish to sleep the device in this state, and only wake should the valve begin moving, i.e. change in analogue input voltage. Im using a PIC18F, but find my self scratching my head a little with regards how I detect this change in voltage to the ADC to trigger an interrupt and hence wake the device.
My logic has brought me to the practical solution where if I could constinously sample at a set rate and store the AI voltage and continuously compare it to a live AI voltage value. I wondered if a sample and hold IC would be good enough to facilitate this then use the PIC18F comparator to trigger an interrupt when a differential is detected. I had considered using the DAC to provide a dynamic Vref to the comparator, but its only 5-bit on this PIC and isn’t good enough for my application.
Any thoughts on my proposal, and or any better ideas??
