Comparator
Discussion in 'The Projects Forum' started by dcar2013, Apr 22, 2013.
  1. dcar2013
    Jan 18, 2013
    8
    I'm trying to complete this circuit (see attachment). LED should turn on when input is less than 8 or greater than 12.
  2. edwardholmes91
    Member
    Feb 25, 2013
    200
    20
    What specifically do you want to know? If this is a homework question then it's really better off in the "Homework Help" board. People aren't going to be willing to answer your question if you don't provide any input yourself. Everyone who posts here does it to help others and learn from others... not just to get answers. Show a little more willing or at least an attempt at the question and you might get some help.
  3. kubeek
    Sep 20, 2005
    4,689
    806
    First start with the led. What logic level do you need for it to turn on?
    Then the NOR gate - what input you need to get that output logic level?
    Then the comparators, what number do you need to compare with to get those outputs?
  4. joeyd999
    Jun 6, 2011
    2,757
    2,932
    Good luck! Let us know how it works out.
    edwardholmes91 likes this.
  5. dcar2013
    Jan 18, 2013
    8
    I want to know how to connect the inputs for this circuit to operate properly I've made several attempts at it with no success.
  6. GopherT
    Nov 23, 2012
    6,312
    4,031
    Check that you have DC power to each chip, a common error because + and - power are not normally shown on the schematic, it is assumed that power is supplied to the appropriate pins of each chip, only the logical inputs and outputs are shown. Look up the Datasheets for each chip on google.com for the appropriate pin assignments.
    Then, take a nice photo of your project so we can help with wiring errors and give more advice.
    Good luck.
