Comparator
Discussion in 'General Electronics Chat' started by Mazaag, Oct 16, 2007.
  1. Mazaag
    Thread Starter Senior Member
    Oct 23, 2004
    255
    Hey guys,
    I have a question about comparators..
    Is the transition from high to low (or vice versa) abrupt? or does it gradually decrease (or increase) ?
    I'm using a LM324..
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Well, an LM324 is a quad op amp, but it can be used as a comparator. Something like the LM311 is really more like it.
    A comparator should make a very abrupt switch from high to low, or the opposite. The idea is to instantly signal when the voltage level has got to the setpoint.
  3. Distort10n
    Dec 25, 2006
    429
    Comparator datasheets should have a specified response time based on supply, and input voltage overdrive.
    Using op-amps as comparators is really a cookbook idea, and should not be used in precision applications.
  4. Mazaag
    Oct 23, 2004
    255
    Does anyone know of a Dual or Quad version of the LM311 IC ?
    Why is a quad op-amp IC like the LM324 inefficient to implement comparators?
  5. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Look at the slew rate of the opamp, and then look at the large signal performance.
    Ideally a comparator output should be digital. It's is really hard to make the output of an opamp look like a logic signal.
    Some of the newer comparators from OnSemi and others give you a choice of open collector or complementary outputs.
    The LM311 is a sensitive beastie. I would suggest the LM393(dual) and the LM339(quad) or their single piece equivalents to get your feet wet. On the scope you will notice the rapid tranition of the open collector output when it goes low. The size of the pullup will determine the rise time in the other direction.
  6. Mazaag
    Oct 23, 2004
    255
    hey guys,
    I just got a LM311N .. i'm planning on using a 5V single supply ...
    There is a ground and a V- pin... do i have to short those? or do i just connect the negative termainal of my battery to V- ? or ground ?
    Thanks guys
  7. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Did you download datasheet(s) for it?
    I suggest you go to National Semiconductor's website and get it.
    There are some application notes in the sheet.
    You could also go to other websites like alldatasheet.com, datasheet4u.com and many others; see the Resources thread elsewhere on this site.
    Life would be so much easier if we could just find the manual for it ;)
  8. Distort10n
    Dec 25, 2006
    429
    The LM311 should have Vcc, Vee, IN+, IN-, Balance/Strobe, Balance, and two outputs. The LM311 is open collector AND open emitter.
  9. Mazaag
    Oct 23, 2004
    255
    what do you mean by open emitter and open collector?
  10. Distort10n
    Dec 25, 2006
    429
    Some comparators are open collector where you need a pull up resistor to some voltage. This allows the comparator to operate at higher voltages than operating Vcc, but not higher than the devices ABS MAX rating on Vcc.
    The LM311 is also has an open emitter to allow you to have a pull down resistor as well. If not, you can simply ground the emitter, and use a pull up on the collector output to Vcc.
