comparator
shivashankari.c14
Joined Apr 6, 2010
10
hi will comparator compare ac signal wit dc signal?i need one circuit which compares ac signal wit dc ref voltage and it must produce output 1 if its voltage s higher than the ref voltage r else it must produce 0 output.
thank u
ifixit
Joined Nov 20, 2008
652
  1. Rectify and filter the AC signal first to get a DC equivilent of the peak AC value. Use resistors to scale down to an average value, or an RMS value (if the AC is a regular shape) as required.
  2. Now compare the two DC levels using a comparator.
Regards,
Ifixit
Engr
Joined Mar 17, 2010
114
Is the 1 and 0 logic levels? Here is a sample circuit using a comparator. The reference voltage is 0V/ GND. While the AC signal is greater than 0V/ GND the output will always be 12V. Other than that it will be 0V.
