Comparator
Discussion in 'Homework Help' started by omerysmi, Nov 13, 2014.
  1. omerysmi
    Oct 10, 2014
    44
    Vi > 4v => Vo= -5v
    Vi < 4v => Vo = 5v
    Am I right?
  2. MrChips
    Oct 2, 2009
    12,642
    3,457
    Many commercially available comparators come with open collector output. You need a pullup resistor on the output pin.
    Usually the output stage is referenced to ground. Hence the output voltage is 0-5V.
  3. crutschow
    Mar 14, 2008
    13,505
    3,383
    You are correct for an ideal comparator. The output voltage may not reach the rails for actual devices.
  4. omerysmi
    Oct 10, 2014
    44
    of course..this is an ideal comparator
