comparator with hysteresis, upper and lower trigger points
Discussion in 'Homework Help' started by PG1995, Nov 13, 2012.
  1. PG1995
    Thread Starter Active Member
    Apr 15, 2011
    753
    5
    Hi
    Please help me with this query. Thank you.
    NOTE: In the reference, given at the bottom in the attachment, there is no mentioning of upper hysteresis limit. So, perhaps there is a typographical error.
    Regards
    PG
      File size:
      245.3 KB
      66
  2. WBahn
    Mar 31, 2012
    18,087
    4,917
  3. Austin Clark
    Dec 28, 2011
    409
    44
    Hey. Do you mind letting us know what book that's from? Looks pretty decent.
  4. Ron H
    Apr 14, 2005
    7,050
    657
    It's a typo, but we can't tell for sure what it should read until we see the fig. 10 .
    If it's the same as fig. 13.7 (inverting Schmitt trigger), Then the statement should read "The output snaps high when the input signal crosses the lower hysteresis limit in a negative-going direction, and it remains high until the signal crosses the upper limit in a positive-going direction."
    Of course, you could deduce this by reading the upper part of your attachment.
  5. PG1995
    Apr 15, 2011
    753
    5
    Thank you, everyone.
    Sure.
    The Figure 6-10 (which I think you were referring to) does not show any circuit. But as it has been suggested by someone that it could be the case that the top reference is talking about inverting Schmitt trigger and the other one about non-inverting configuration. Thanks.
    Regards
    PG
  6. Ron H
    Apr 14, 2005
    7,050
    657
    Fig. 6-10 is obviously describing a noninverting Schmitt trigger.
    PG1995 likes this.
