comparator reference voltage
eyuge2
Joined Nov 18, 2005
i have a question about the comparator LM311.
we have a comparator circuit.a sigle voltag(+15V)supply the comparator, the referece voltage is connecting to inverting input,the value is 0.175V.
at the TI LM311 datasheet,the common mode voltage min value is 13V to -14.5V. i think if the lower power supply value is 0V, the common mode voltage can't less than 0.5V.
this circuit,the reference voltage is 0.175V,less than 0.5V. is the circuit is right?
thanks!
You are correct. The recommended operating conditions for V(in) is between Vcc(-) + 0.5V and Vcc(+) - 1.5V. Therefore, the recommended input range is between 0.5V and 13.5V for a single +15V supply. And, based on the V(common mode) the range may only reach 13V at the upper end.
With a reference voltage of 0.175V, the circuit will probably not operate as you would like.
