Comparator in LTspice, Current flows beween + and - supply?
Discussion in 'General Electronics Chat' started by masteropie, May 24, 2008.
  1. masteropie
    May 17, 2008
    26
    Why does 4ma flow between the + and - supply in this spice simulation? I could not find anything in the data sheets that talks about this. Is this normal in circuits?
    • Comp.asc
      File size:
      874 bytes
      64
  2. Distort10n
    Dec 25, 2006
    429
    Yeah, check out Icc: 4mA typical.
    As to why it is negative, where are you placing the virtual ammeter? If you measure across the supply, it will read -4mA; however, if you measure at the positive 'pin' of the schematic it will read +4mA.
  3. Ron H
    Apr 14, 2005
    7,050
    657
    Unrelated to supply current, but you need a ground return for your signal source. It does not necessarily need to be tied directly to ground, but there needs to be a current path.
    I'm also curious why you have 1k resistance in your power supply.
    The absolute maximum supply voltage on the LT1720 is 7 volts (you are using 15). Is that because you were experimenting with the supply current?
