I'm using a TIA followed by a comparator in order to convert an optical signal received by a photodiode (a sequence of 0s and 1s) into a corresponding electrical signal that's 0 to 5 V. This is to allow an optical link to be used in place of the previous electrical link.
The circuit seems to function perfectly well, converting the optical signal into an electrical signal. However, a couple of the comparators have failed - I observed it suddenly trying to draw a large current from the power supply (200 mA or more), followed by a drop in that current and a subsequent inability to output 0 to 5 V signals.
My guess is that the way I had things set up meant the comparator output was delivering a much higher current than it was rated for, causing the part to heat up and eventually fail. The max. output current is given as +/- 50 mA, together with a note that at such a current "a heat sink may be required to keep the junction temperature below the absolute maximum rating". I had things set up so that the comparator output was 0 to 5 V, delivered to a 50 Ohm load of an oscilloscope - so would the comparator output current therefore be nominally far too high (e.g. up to a max 5V / 50 Ohm = 100 mA?) and fried the part?
The part in question is the Linear Circuits LTC6752, in the MS8 package. The circuit is very similar to that shown in Figure 10 on the data sheet. The input voltages to the comparator inputs were about 1 V.
I'm just looking to get confirmation (or not!) that I've identified the cause of failure, and some pointers on how to avoid it (I'm thinking - change the scope load to 1 MOhm, put on a heat sink maybe...)
Thanks!
Thanks!
