Comparator for supply range 16.8V
Discussion in 'General Electronics Chat' started by Vindhyachal Takniki, Jan 19, 2016.
  1. Vindhyachal Takniki
    Nov 3, 2014
    357
    6
    1. I have a battery powered application which is powered application from 4S li-ion cell. (12V - 16.8V). I need a comparator for this. Comprator output will drive a mosfet FDS6690A, which is basically in current path.
    2. Comparator has to be very low powered since it is battery powered application. I have checked TLV3701 from texas instrument. Datasheet says it for upto 16V, but absolute max can go upto 17V. Can I use it here?
    3. Another option is to use LT1716(upto 44V), but its current can upto 85uA at 12V. So I haven't consider it yet.
    4. Any other very low powered comparator for 16.8V supply & to drive FDS6690A.
  2. Picbuster
    Member
    Dec 2, 2013
    391
    53
    pls provide more info like a drawing and description what you want to compare and when < => what action to take?
  3. #12
    Nov 30, 2010
    16,671
    7,314
    How about this one at 5.5 ua (typical)?
  4. Vindhyachal Takniki
    Nov 3, 2014
    357
    6
    Attached is the circuit, if I use TLV1701. Have to drive a mosfet which will cut the load current. Input of comaprator has to compare between 3.3V & 1.5V.
    Only problem is at V+ side of comparator, wich exceeds 16V limit.
    Looking for some series diode which can be added. Problem in that case may be that series diodes themselves have very low Vf at current in uA range. e.g http://www.digikey.com/product-detail/en/1N4148X-TP/1N4148XTPMSCT-ND/789335 has drop of 0.2V at 10uA
    Problem with open drain, is everytime current will be consumed when output is low. as in attached circuit
  5. ErnieM
    Apr 24, 2011
    7,436
    1,625
    Your schematic has no comparator shown.
    I know you need need to choose one, but for that we need to see where you are using it.
  6. PeterCoxSmith
    Member
    Feb 23, 2015
    148
    38
    TLV1701 has this spec:
    What is the problem?
  7. Vindhyachal Takniki
    Nov 3, 2014
    357
    6
    Attached is my circuit.
    1. MCU takes one input(J3, voltage), do some processing & then turn P1.7 high or low. When P1.7 is high, it gives high to comparator, which in turn on the FDS6690A, & turn off if p1.7 is low.
    2. Can I turn on/off mosfet FDS6690A directly by MSP430(3.3V)? Datasheet says VGSmax = 3V, when VDS=VGS & IDS = 250uA.
    In my case max Vds will be 16.8V & max current will be around 7A.
    If yes, then I can remove comparator.
    • MCU.pdf
      File size:
      19.4 KB
  8. Papabravo
    Feb 24, 2006
    10,340
    1,850
    LM393(dual) or LM339(quad) will handle up to 36V single supply and have an open collector output.
