Comparator circuit
Discussion in 'The Projects Forum' started by salmanrobo, Aug 13, 2010.
  1. salmanrobo
    Aug 13, 2010
    Hi there....
    I wanted to make a circuit which senses two voltage levels.....If the voltage level is below 43 it gives 1 and if if above 43 and at the same time below 55 it gives 0...Is there any practical comparator available that works at this voltage?
    I thought of connecting a relay and a 43 vol DC battery to the out put of the comparator..How does this idea sound...Need help....Thank you
  2. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,384
  3. salmanrobo
    Aug 13, 2010
    Thanks! I actually found a circuit....But the weird problem is that the source that is fed to the comparator is actually a super-capacitor..When it's voltage drops below 43 V I want it to get charged but due to the resistor arrangement as shown in the circuit it should get discharged..So what about it....?
