Comparator as a current to voltage converter
Discussion in 'The Projects Forum' started by Nano001, Feb 5, 2010.
Thread Status:
Not open for further replies.
  1. Nano001
    Thread Starter Active Member
    Jan 12, 2010
    88
    Hi everyone. I recently breadboarded the attached circuit to amplify the current from a photodiode. I would now like to use LT1016 in replacment of the LM324 for high frequency photodiode current pulses (10-13MHz). I was wondering if using this comparator as an opamp is as simple as just adding a feedback resistor from the output to the inverting input. Once I get this circuit working I was told that I need a preamp due to large capacitance of the highly revered bias operation of the diode. First, however, I would like to just test this device at low frequencies until I optimize the design then I will transfer the circuit to a high freqyency PCB for testing in the 10-13 MHz range.
  2. mik3
    Feb 4, 2008
    4,846
    63
    You cannot use a comparator as an analog amplifier. Comparators do not have a compensating capacitor and their output is an open collector type. You have to use a high frequency op amp if you want a high frequency amplifier.
  3. Nano001
    Jan 12, 2010
    88
    Any suggestions as to what opamp I should get for this high frequency. I ws told on this forum that the LT1016 would work. Thank you.
  4. mik3
    Feb 4, 2008
    4,846
    63
    If you want just to amplify the pulses of the photodiode then a comparator (you can use the LT1016) will be ok. If you want to measure the intensity of the light incident on the photodiode then you will need an op amp.
  5. Audioguru
    Dec 20, 2007
    9,411
    896
    The capacitance of the diode is less when its reverse bias voltage is more. But your reverse bias voltage is only 1.15V.
  6. Nano001
    Jan 12, 2010
    88
    Thanks Mik3. I just need to convert the current pulses supplied by the photodiode to digital pulses (0-5V) which are acheived by the output of the comparator (LM311 in schematic). How can the LT1016 be configured for this? If not, any suggestions on another suitable opamp?
    Audioguru you are right, I said it backwards. The reverse bias of the diode is actually at ground for now, until I want speed.
  7. mik3
    Feb 4, 2008
    4,846
    63
  8. Nano001
    Jan 12, 2010
    88
  9. Audioguru
    Dec 20, 2007
    9,411
    896
    ST Micro have terrible copies of the datasheet from National Semiconductor.
    The LF355, LF356 and LF357 opamps do not work with a supply as low as 5V. The datasheet shows 10V minimum.
    The inputs will not work if they are less than +3V in your circuit.
    The fast LF357 needs a minimum gain of 5 or it will oscillate.
    Use an MC34071 single or MC34072 dual opamp that will work in your circuit and it is pretty fast.
  10. Nano001
    Jan 12, 2010
    88
    Ok. Unfortunately, the MC34071 has a bandwidth of 4.5MHz, if I read correctly, which is too small. I need 10-13.
  11. atferrari
    Jan 6, 2004
    2,663
    784
    LM318 maybe? High slew rate as far as I recall.
  12. Audioguru
    Dec 20, 2007
    9,411
    896
    The very fast opamps from Texas Instruments have a minimum supply of 10V.
    Like any opamp, their bandwidth is less as you add gain. Your photo-diode has a very low output so you need lots of gain.
  13. Nano001
    Jan 12, 2010
    88
    LM318 has 15MHz bandwidth, however I need single supply +5V. Can the 318 operate in single supply, I didn't see it in the datasheet
  14. Audioguru
    Dec 20, 2007
    9,411
    896
    The LM318 has a minimum supply of 10V.
    Its minimum input voltage is +3.5V in your circuit.
    Its small signal bandwidth is 15MHz when it has a gain of 1 and its large signal output is about 5MHz. Adding gain will reduce the bandwidth.
  15. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    This thread should be closed, as it is open on another thread.
  16. Nano001
    Jan 12, 2010
    88
Thread Status:
