Comparable Op Amp ALD2702A 5v rail-to-rail
Discussion in 'General Electronics Chat' started by wstuck, Dec 3, 2011.
  1. wstuck
    Jun 16, 2009
    14
    I want to use an ALD2702A 5v rail-to-rail op amp in my circuit but the circuit design software does not have it as an option. Does anyone know what I could use as a comparable op amp choice?
    The ALD2702A is a 5V rail-to-rail op amp (see attached spec sheet)
    Thanks for your help.
  2. Audioguru
    Dec 20, 2007
    9,411
    896
    Since you cannot find the model of the opamp for your simulator then why not build and test the circuit instead of simulating it?
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
  4. wstuck
    Jun 16, 2009
    14
    Thanks you for all of your help and suggestions. I am new at this but am learning something new every day. Your information is very helpful.
