Compact Bluetooth transmitter system with 5 channels
Discussion in 'The Projects Forum' started by RB_51, May 20, 2014.
  1. RB_51
    May 20, 2014
    My knowledge of electronics is very limited and I'm looking for some advice on a project.
    I am in need of a compact Bluetooth transmitter that will accept 5 channels of input from noise pulse signals (probably piezo resistive sensors) and transmit them to a Bluetooth capable device eg. smart phone.
    I have looked into Arduino boards and searched generally for Bluetooth transmitters. I'm not clear from the descriptions of the Arduino boards whether I can simply plug in different source signals and have it decoded by a receiving device or whether multiple boards are needed to arrange/decode the information.
    If anyone knows of a straight forward and compact way of transmitting up to 5 channels of data via Bluetooth I would very much appreciate the advice.
  2. shteii01
    Feb 19, 2010
    3,515
    515
    Now break it down into blocks and do block diagram.
    The easiest way to do it is to use 5 receivers to receive data from the sensors. Use 1 transmitter to send info to the phone. And control receivers and the transmitter with uC.
