Communications Systems Questions
Discussion in 'Homework Help' started by Adille, Apr 11, 2016.
  1. Adille
    Mar 10, 2014
    Hey guys have a small exam comming up, and I've got few questions I am not too sure of could someone take a look and guide me in the right direction.
    1. An accelerometer in a fall sensor system is band limited to 5Hz. If the system is operated at 5 times oversampling, what sample rate will be used?
    I assume thats 5Hz * 2 (the nyquit rate) * 5 ?
    2. The same sensor incorporates a three axis accelerometer and three single axis gyroscopes. If the sample rate is now 100Hz and the samples are 16 bit per measurement channel, calculate the required bit rate.
    Is someone could explain how to go about getting the answers to those I would be very happy, thank you in advance.
  2. WBahn
    Mar 31, 2012
    18,085
    4,917
    How many data values do you get our of the sensor per sample? How big is each data value, in bits? How much data do you get, in bits, every second?
  3. Adille
    Mar 10, 2014
    I am only looking for the sample rate and the bit rate. And its to be calculated from the information I am given in the question
  4. WBahn
    Mar 31, 2012
    18,085
    4,917
    So, given the information you are given in the question, in the second problem how many data values do you get out of the sensor per sampling period? How big is each data value (in bits)? How much data do you therefore get, in bits, every second? What does that mean as far as your bit rate?
  5. Veracohr
    Jan 3, 2011
    559
    77
    You're correct on the first question, although one could argue that the sample rate doesn't HAVE to be exactly twice the bandwidth, it could be even greater. So the question is worded in a way that can be confusing or lead to mistaken assumptions for some people.
