Communication between labview and CyUSB
Discussion in 'Embedded Systems and Microcontrollers' started by johnkaz77, Apr 29, 2011.
  1. johnkaz77
    Sep 20, 2010
    33
    Hi everyone!I want to use labview in order to control Cypress USB controller (CY7C68013),has anyone done anything similar?I'm having problems trying to communicate with CyUSB and i could really use some help.
  2. t06afre
    May 11, 2009
    5,939
    1,222
    Hmm....The datasheet is quite big. Not something you just can take a quick glance at. And get the full picture. Can you tell you tell what you have done so far and why and how you struggle.
  3. johnkaz77
    Sep 20, 2010
    33
    Thank you for your reply!I know,the datasheet is quite complicated..I've found the CyUSB .NET dll and i have load it into labview through the .NET palette.And after that is where my problems begin..I see a list of objects and the related constructors when i open the constructor node and i don't know what to do...
    How can i access the endpoint buffers (in order to perform read or write operations) and control the vendor requests?
  4. GetDeviceInfo
    Jun 7, 2009
    1,571
    230
