Common transistors and capacitors for lab
Discussion in 'General Electronics Chat' started by mrmeval, Oct 2, 2007.
  1. mrmeval
    Thread Starter Distinguished Member
    Jun 30, 2006
    833
    I'm looking for a good list of them. I'd buy one of those pre-made kits if they were not someones junk.
    This will be for digital and low voltage work. Opams, 555 timers, arudino, LEDs and both cmos and TTL devices.
  2. eeboy
    Sep 27, 2007
    90
    BJT's:
    NPN ---> 2N2222A, TIP21
    PNP ---> 2N2907A
    Caps:
    Ceramic .001uF, .01uF,.1uF,.47uF,1uF with minumum 16V rating
  3. ixisuprflyixi
    Sep 16, 2007
    52
    well NPN is 2N3904, BC546, BC182
    and PNP is the 2N3906, BC556, BC212
    and they are in the TO92 case. that is the small through hole package with the leads and in the common EBC configuration
  4. cumesoftware
    Apr 27, 2007
    1,330
    11
    The TIP31 and TIP41 NPN transistors.
    The complementary TIP32 and TIP42 PNP transistors.
    Capacitors:
    1000uF 25V aluminium electrolytic;
    470uF 25V aluminium electrolytic;
    220uF 25V aluminium electrolytic;
    100uF 25V aluminium electrolytic;
    47uF 25V aluminium electrolytic;
    22uF 25V aluminium electrolytic;
    10uF 25V tantalum electrolytic;
    4.7uF 5V tantalum electrolytic;
    2.2uF 25V tantalum electrolytic;
    1uF 25V tantalum electrolytic;
    0.47uF 5V tantalum electrolytic;
    0.22uF 25V tantalum electrolytic;
    0.1uF 25V tantalum electrolytic.
    Op-amps:
    LM741;
    LM324;
    LM339 (comparator).
    Voltage regulators:
    LM317 and LM337 (adjustable regulators);
    LM7805;
    LM7812;
    LM7912.
  5. nanovate
    May 7, 2007
    665
    Jameco http://www.jameco.com or Digikey sells kits.
    Also do not forget MOSFETs both standard IRFZ44N and IRF9Z34N and some "logic" ones.
    Also some heatsinks for TO220s
  6. mrmeval
    Jun 30, 2006
    833
    Thanks for the info!
