Common Source amplifier
Discussion in 'Homework Help' started by alphacat, Jan 25, 2010.
  1. alphacat
    Thread Starter Active Member
    Jun 6, 2009
    186
    Am I correct about the exact (not approximated) output resistance of this amplifier?
    Rout = (RD || ro) * (1 + gm * RE)
    Thank you.
      File size:
      17.5 KB
      113
  2. Jony130
    Feb 17, 2009
    3,991
    1,116
    For me the equation look OK.
  3. t_n_k
    Mar 6, 2009
    5,448
    783
    If it were the 'exact' value I would have
    Rout=RD||(ro+RE+gm*ro*RE)=RD||{ro*(1+gmRE+RE/ro)}
  4. Jony130
    Feb 17, 2009
    3,991
    1,116
    Well I think that correct answer is
    Rout = RD || (ro* 1 + gm * RE)
  5. The Electrician
    Oct 9, 2007
    2,300
    335
    alphacat has some misplaced parentheses:
    should be:
    Rout = RD || (ro * (1 + gm * RE))
    Jony130 appears to intend this same expression, but has missing parentheses.
    This expression, Rout = RD || (ro * (1 + gm * RE)), is a good approximation provided that ro >> 1/gm.
    tnk has it exactly right.
    This circuit is used as a phase splitter in audio practice:
    http://en.wikipedia.org/wiki/Phase_splitter
    and was first used in vacuum tube circuitry:
    http://en.wikipedia.org/wiki/Valve_audio_amplifier_-_technical
    If RD and RE are identical, then the voltage gain from gate to drain is identical to the voltage gain from gate to source, thus providing a pair of outputs identical in amplitude but 180 out of phase.
    This circuit has been the subject of much controversy in the audio world because the output impedance (driving point impedance) at the drain is different than at the source. It would seem that if the two outputs (drain and source, or plate and cathode if tubes are used) are loaded with identical impedances, the balance would be upset, but this is not the case.
  6. Jony130
    Feb 17, 2009
    3,991
    1,116
    Yes, my mistake.
    This equation Rout=ro * (1 + gm * RE)) I took from the book and it was not a single word about simplification.
    So I decided to find Rout by myself.
    Rout = V2/I2 for V1 = 0V Vgs = (-I2)*Re
    V2 = ( I2 - (gm*(-I2)*Re) )*ro + I2*Re
    I2 = V2 / ( Re + ro + gm*Re*ro )
    So
    Rout = Re + ro + gm*Re*ro
    And that means that tnk equations are OK.
      File size:
      14.2 KB
      92
