common motor in toys
Discussion in 'General Electronics Chat' started by neiji, May 26, 2008.
  1. neiji
    Jul 25, 2007
    19
    I would like to have some technical data on the motor which are used in toys, which is supplied by 6v.
    Data required would be
    1) type of winding parallel/series
    2) torque
    3) inductance, resistance
    4) torque,etc
    these values would be used for simulation purposes.
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    You may have better luck selecting a motor from a manufacturer of motors.
    You would benefit in at least of couple of ways by selecting a motor from a manufacturer.
    1. You would have access to the motor's electrical and mechanical specification.
    2. You would be able to purchase the motor for use in your project.
    hgmjr
  3. mik3
    Feb 4, 2008
    4,846
    63
    Check if there is a number written on the motor and use this number to search in google for this motor.
    I found one for you on this website: http://www.electronics123.com/s.nl/it.A/id.1953/.f
    I typed "6V DC motor" and many results appear. Try it.
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Have you considered how many toys there are with motors in them? Mabuchi is one common manufacturer. You could get the spec sheets on the line of Mabuchi motors, I suppose.
